Hi,
I use Ulead DVD Moviefactory. When I add a file, the bar at the bottom will show something like 4,4 GB filesize. Not in the red zone or anything.
I add a few chapters and then convert, multiplex and try to burn. Then I get a msg "File too big. Insert new media". When I check the VIDEO_TS-folder, the sum is something like 5 GB. This have happend several times for me.
What do I do?? What is the best way to cut the original file into 2 files so I can burn them?? Or is there a better way?? Maybe so I can get the file on one DVD.
Cheers,
Mike
sounds like compressed audio is getting uncompressed into lpcm (uncompressed) - see guides on adding ac3 to your project (i dont use ulead so cant tell you)
Then use MPEG Audio, it is compatible with most DVD Players.
Thanks! I will try it. Guess that is a form of compressed sound so the files don't get so big, right?
Yep, PCM/WAV audio is around 10 MB/ minute while compressed MPEG2 or AC3 is around 2-4 MB/minute.
How to split a .TS video file based on time (not file size!) ?
By Michael REMY in forum EditingReplies: 4Last Post: 19th Sep 2020, 19:32 -
how to split mkv file and subtitle file to play on blu ray via hdd usb
By julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 12:28 -
Best way to split an MPEG file is to ???
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 10th Mar 2009, 21:31 -
how to split a FLAC file?
By tomchook in forum AudioReplies: 4Last Post: 9th Mar 2008, 23:04 -
split one file avi in two
By Jomapil in forum Newbie / General discussionsReplies: 4Last Post: 8th Mar 2008, 15:13
