  1. I'm looking for a program that will let me create VCD's with menus as rich and detailed as any DVD. I also want to create a slide show, like you find on many "extra" DVD's.
    I'm currently using Nero, but I don't care for its menu editor.
    Thanks,
    -William R. Cousert
    wrcousert@yahoo.com
    Feb 2002
    nyc
    Check the tools section to the left. I use Ulead dvd moviefactory(try the free 30-day download). for more involved menus( motion) try Ulead dvd workshop hth,
    Bloo
  3. Member Cornucopia's Avatar
    Just about anything that can be done within the VCD and SVCD specs (and a little that go beyond) can be done--FOR FREE--with VCDImager, and GUIs for it such as VCDEasy.
    You would need to use a photo editor to prep the menu graphics/photos, or a video editor to prep the movies/motion menus, and of course a high quality MPEG encoder such as TMPGEnc, but all else is easily done within the apps. Gives you a very capable, compliant disc. I use it over all the others. With a little bit of cheating/imagination, you can give a user an identical experience to that from a DVD.
    I heartily recommend these apps.
