I attempted to trick my DVD player to recognize a SVCD using the VCD header trick, but it did not work very well. The DVD player actually views it as a VCD and starts to play it, but all I get is a blocky version of the DVD player's menu screen with full audio. Strangely enough, my computer' DVD player has no problem playing it.
I captured with VDUB and converted with TMPGEnc, with "Interlace", "Top Field First (A)", "4:3 Display", and "Full Screen (Keep Aspect Ratio)" selected, and nothing below checked on the "Advanced" tab. Then I ran a Simple Multiplex with "MPEG-1 Video CD" selected and received a warning that it might not play properly. Finally, I burned it to a CDR, with Nero, as a VCD. Nero also gave me a warning.
Any idea what I might have done wrong or how I can make it work on my DVD player? Is it not working because of any of the settings I listed above?
Did you Multiplx using MPG-1 Video-CD (non-standard) or MPG-1 Video-CD
Some Day I will….. -
I think my mother in law owns this exact same DVD player. If it is, IT WILL NOT PLAY SVCD's no matter what. The fact that you got it to play at all is a miracle. Again, basing all of this on having the same dvd player.
If it isn't is sounds like you have done all you can to make it work. There are some DVD players that will not do the trick. My only suggestions, and you wont like it, is to get a dvd player that plays different formats. You can get the cheapos like apex and mintek that play everything. They are wallyworld specials for $40-$50. Sorry could provide more assistance. -
Tried it the other way... exact same result. Might changing any of the other settings make it work properly?
what is the bitrate set at?? some of the older player will not play much over 2000 -2050
Need a multi view video player- ADVICE PLEASE
By rosewarburton in forum Newbie / General discussionsReplies: 0Last Post: 27th May 2010, 08:49 -
What video player to view videos accurately?
By ayim in forum Newbie / General discussionsReplies: 3Last Post: 20th Dec 2009, 10:06 -
How to view .mpg video and subtitles in QT Player?
By davecc in forum MacReplies: 6Last Post: 26th Jun 2009, 08:22 -
Desay dvd player to view on my computer ...how?
By Boothbay in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2008, 11:58 -
best app for burn a video clip to view on a DVD player?
By yolao in forum VCDEasy GeneralReplies: 0Last Post: 8th Jul 2007, 13:34
