Results 1 to 30 of 43
  1. anyone try the new patch for ic7? is it faster? is the quality better as they proclaim? how about the video size is it closer to 4.38?
  2. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    yes
    yes
    dunno yet, have my doubts until I test it
    no
  3. just tried the new patch with a movie i cut down to movie only with dvd shrink. The movie was 3.16 g....thats not even close to 4.38...did i do something wrong????
  4. Banned
    Feb 2003
    Columbus, Ohio
    if u are try to burn a movie already shrunken to 4.38g from another program, click direct (not recommended) on the copy method on the dvd tab of the details section
    Feb 2003
    Land of Oz
    That depends. What size was the movie before you let IC7 loose on it?
    (ie. after DVD Shrink, but before IC7).
    The glass is neither half-full, nor half-empty.
    It is simply twice as big as it needs to be.
  6. Yes, update3 seems better,
    did red dragon a few days ago. came to 3.5
    now with justa little over shooting, its past
    4.36, so i guess just leave it to max and
    see what happens...
  7. I ran the update3 and my version says 7.0.3.140, 5/15/2003. Am I on right version?
  8. One thing I like is the CLI commands.
    I was able to setup a simple batchfile to rip and process in 1 click.
    See Ex:
    del c:\instant\*.* /q
    del d:\image\*.* /q
    "C:\Program Files\DVD Decrypter\DVDDecrypter.exe" /mode file /src g: /dest c:\instant /files all /start /overwrite yes /close
    "C:\Program Files\InstantCD+DVD\InstantCopy\MultiCopy.exe" /srcimage c:\instant\video_ts.ifo /dstimage d:\image\image.pdi /autostart
    Aug 2002
    IComeFromALandDownUnder
    Downloaded it just now, it says the following:
    Bug Fixes/Improvements:
    Better usage of destination disk capacity
    Optimized video quality
    Overall speed improvements
    "Phantom cell sets" fixed
    Still picture problem fixed (occured in menus with sound)
    Demux errors fixed (aka SID error)
    What is new in this version 7.1.1:
    The main improvements are a significant speed increase for the DVD transcoding (approx. 30%-50% faster) and a new analyze method for better target disk size usage.
    Various registry settings were added. For more information, please report to our support Knowledge Base.
    Key combinations (no support available for this function)
    F5 : Enable the OK button ignoring all size issues
    F6 : Saves the currently selected percentages/titles/streams for this DVD
    F7 : Load (if previously saved) settings for this DVD
    Batch Processing functionnality. For more information, please report to our support Knowledge Base.
    I haven't tested it just yet but I will and let you know the results.
    Feb 2003
    Land of Oz
    Nice.
    Now that would make this process easier to deal with whilst there is a screaming baby/babe in the background.
  11. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    posted this on the Pinnacle board
    it's processing faster (but at what cost?)
    you can change the default size from 4.32 to anything you want
    it does recognise the missing MB's in my DVD's
    you can do batch processing
    the reg setting of DVDVideoSaveBorder is interesting cos it looks like a black bar issue fix. (but why a reg setting?)
    still hogs the PC's active window and pops up all the time after a process is finished and is easy to accidentally Cancel!!
    still undersizes big style
    if you save the settings it doesn't remember the percentages and just does an automatic resize
    didn't recognise the 'true' size of a known problematic DVD
    still only PDI output
    and also this
    both my problem DVD's I uploaded now work fine with update
    good work
    but it still not right on certain DVD's regarding the 'phantom MB's' but I cannot complain due to the disclaimer so I'll just make another to recreate it
    I think it's cos not only the first PGC in a Titleset can be a 0.xx sec entry as the others can be too
    dunno bowt the crashing during long blank sequences on the other so called problem DVD's but like I said both issues work just fine on my two problematic DVD's
    more feedback HERE
    Nope, it still undersizes big style and if you do movie only with a 2.35:1 this is what you get
    Yep, that's the version
    'Phantom Cell sets' ain't fixed , they have fixed it so that the DVD'S I sent them (cos they don't offer Copyrighted material support) worked with the new update, but it still don't recognise the 'true' size of the disc cos I tried a problem one HERE I had before and it's still the same, 6.77Gb until I automatic resize it !
    the speed is faster but I'm doubting if the quality is the same until I do some tests cos I ain't bothered if it's 30-50% faster if the quality is gonna suffer. I'll post results as soon as I can
  12. I can't even install the patch ! it say can't find Instant Copy Installation or your COmputer... but it is installed.. Update 2 didn't have this problem.
    I have reinstalled IC7, put Update 2, but Update 3 still say the same thing
  13. from Pinacle website:
    When I try and run the 7.01 or 7.02 Instant Copy update i get the error: "Can not find Instant Copy. This update requires an installed full version of InstantCopy."
    Answer
    You likely have Instant CD/DVD which includes Instant Copy as one of the features. The 7.01 or 7.02 patch update will not patch the Instant Copy that comes with this version. Most of what was fixed in 7.01 and 7.02 was included in Instant CD/DVD before it was reased.
    Cool.. I pay for a software that can't be updated.. what a nice services by pinacle !
  14. Thanks MackemX.
  15. the movie that came out to 3.2 g was originally cut with dvd shrink and was like 6.1 g before running through ic7. Should i select a larger target size (oversize it) or what? i did 2 other emovies (not using dvd shrink before compressing with ic7) and they cmae out to like 4.36g and 4.31g, so i think it may have something to do with dvd shrink...not sure though. i could really care less about the wasted space but the end result was blocky (not sure if this is because of the new "quicker" processing), i am going to burn a movie tonight that compressed to 4.31g and ill let u know how it turns out.
  16. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    did you crop the end titles by any chance?
    is it 2.35:1 ratio, as in does it contain black bars in the image?
    if the answer is yes to one or both of these questions then that's your answer for undersizing
    Pinnacle aint fixed the undersizing issue regarding letterbox movies but 1.85:1 movies seem to be a bit better
    if you do a movie only you will get more undersizing than doing a 1:1 unless its a 'true' 4:3 DVD
  17. Where exactly can I download the update? I checked the pinacle site, but they just have the first update listed.
    Cheers,
    Finley
  18. Hi Silvergator,
    You can get it from here.http://forum.doom9.org/showthread.php?s=&threadid=53732
    Good luck.
  19. Originally Posted by vric
    Answer
    Nice eh? The translation for "likely" is "well we might have screwed something up" and for "Most" is "most of the stuff is probably the same just not the important stuff that matters."
    I used to do lots of editing back in the day and used some Pinnacle products but the software side of things always sucked. When Matrox put out the RT2000 a few years back tons of us jumped ship, mostly due to bad software from Pinnacle.
    Lightnin'
  20. Originally Posted by lightnin
    Answer
    Lightnin'
    I resolve the problem.. Downloaded the version on the internet somewhere and used my serial number.. it's a shame your retail software didn't work with patch
    anyway, I just did one Test, and the file size look better ! I usualy put 4.5gig to get a file of 4.2Gig, so today I made a backup and asked 4.54 and get a files of 4.5gig !! hehe need to rips some extra with ifoedit
    May 2003
    It is all bullshit I did the update patch and the program still crashes on me when I try to back up jurrasic park or die hard 1&2 widescreen versions.Also does anyone know how I can stop this from happening to me it always crashes on me with those movies so if someone has a fix please help me
  22. louthewiz, your original dics may have scratches or not ripped properly. Trying ripping them again.
    If this not work reinstall IC7 from scratch.
    Why don't you try DVD2-R, it takes a little longer but it may work with same sort of quality.
  23. i apllied the update a few days ago and the first couple runs i was REALLY close to the target. but then i tried enemy at the gates and everytime i am ending up with EXACTLY 3.74. it is really wierd i keep upping the size and still get 3.74. i am running it right now with an estimated size of 5 gig. the last one was 4.8 and still gave me 3.74 . i dont get it.
    as far as the speed increase. i have not seen any. still taking my about an hour 30 for an avg movie. and i have a decent machine:
    p4 2.4
    512 pc2700
    ata100 HD w/8 mg cache
    what kind of speed increases have you guys seen?
    also, anyone having this size issue with the new patch?
    after the first two tries and getting the EXACT same 3.74 output size. i uninstalled and reinstalled and applied patch again. i didnt remove the registry settings though. i will if i have to, i was hoping this would fix it.
    any ideas on this shiznit?
  24. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    look HERE
    its the black bar issue
  25. mutha that was quick!!!!
    MACKEM while you are browsing take a look at this one.
    https://www.videohelp.com/forum/viewtopic.php?t=158613&highlight=
    i know i need to use ifoedit but...
    well read the post and you'll see.
    thanks again for the posting speed.
  26. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    right place right time
    p.s. that's email notification for you 8)
  27. Where do I get this update Ive been looking, where is it let me know please thanks.
  28. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    https://www.videohelp.com/forum/viewtopic.php?t=159093
    https://www.videohelp.com/forum/viewtopic.php?t=159154
  29. Banned
    Feb 2003
    Columbus, Ohio
    i never care about the sizing issue before, but antwone fisher is a 5.78 gig movie and i'm coming up with a 3.4 gig final movie which leads me to beleive the sizing issue is worse. what gives?
    i don't think it's the black bar issue, but i dunno
