Maybe this question has been addressed before but I could not find info on it anywhere. This divX plays perfectly fine on my computer in its divX format. I wanted to play it on my DVD player and went to convert it to NTSC format using TMPGEnc. I played this format of the movie on my computer and a pink haze would fade in and then cut out over and over again. I'm guessing macrovision but my real question is is there anyway around this using some sort of setting in TMPGEnc? Thanks in advance for any answers!
...Could you be more precise...
Macrovision is probably NOT the issue...
Macrovision kicks in when you've connected your DVD to a VCR and as far as I know it does so on every thing you play...
Magnus Jensen
A.K.A Geezus -
I would be more percise but I don't know what more to say. When I play this movie in DivX format with windows media player everything is just peachy. I want to play it on my DVD player though and the DivX format can't be played on a DVD player. Using the NTSC preset with TMPGEnc I converted it to a format that would play on my DVD player. I played this file with windows media player and that is when I get the pinking described above.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE> -
I can't figure this out...
Try using the some Color filter (Or check so no filter that change the colors are in use...)
This could fix it, if a colorfilter is in use...
You could of course try to reencode the DivX... (Slow process but it could fix it
Magnus Jensen
A.K.A Geezus
Converting PAL to NTSC?
By Djehuty in forum Video ConversionReplies: 17Last Post: 3rd Sep 2011, 14:55 -
Converting Videos to NTSC MPEG-2 (using TMPGEnc Xpress)
By Quamatek in forum Video ConversionReplies: 14Last Post: 12th Sep 2009, 06:20 -
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 24th Feb 2008, 00:35 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 06:48 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
