Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
Results 1 to 9 of 9
  1. I recently transferred old vhs tapes (30+ years) to dv. I intend to make a dvd.
    I am using Premiere 6.5. Which tools, effects, additional plug-ins can I use to improve the quality of the original clips (e.g. sharpness, faded colors, ..)
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    temporal 2D cleaner flaXen VHS Noise Reduction Filter for virtualdub http://flaxen.dynip.com/vdf/fxvhs/help.html
    other like it for avsyth
    much better results than anything in premiere..
  3. I tried this filter, but the resulting AVI comes 10 times larger than the orginal (e.g. 1.4G for 140 Megs). Is it normal ?
  4. cmangeot, How about the quality?
    It's better than before???
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    A. you should be frame serving it anyway..
    B. it bigger because you didnt set what type of compression you wanted first so it made a uncompressed avi ..
  6. I cannot tell yet. I am going to cut a sample dvd with original/enhanced and check the difference (cannot see in Premiere)
  7. Originally Posted by BJ_M
    Can anyone give me a link on how to successfully frameserve between VirtualDub and TMPGenc?
    What's "taters", precious?
  8. Thank you very much.
