I have an avi that is 750 mb. When i try to put put it on a dvd, it says the file is 7 gigs. Someone told me it was because of the kind of audio that the avi has. the authoring software is converting it to a usable type, and that is why the file is so big. Is there any way to keep the avi video, but just change the audio, so it will fit on a dvd?
More likely than not, whatever program you are using to convert the avi to dvd compliant mpeg2 is converting the audio to PCM, which is rather large.
I would suggest using Tmpegenc found in the Tools section to the left to convert TO DVD COMPLIANT MPEG2 before authoring your dvd, you can then load the resulting mpeg2 file in the authoring program to author and burn.
Mkvmergegui changing audio
By leon_pro in forum Newbie / General discussionsReplies: 4Last Post: 20th Apr 2012, 19:28 -
Changing .avi codecs?
By kwongsauce in forum Video ConversionReplies: 13Last Post: 20th Mar 2012, 09:38 -
changing audio format
By spmint in forum Newbie / General discussionsReplies: 4Last Post: 3rd Feb 2012, 17:21 -
Changing The Audio Of An AVI File "Language" {HELP COMPLICATED PROBLEM}
By Mr CMTS in forum EditingReplies: 1Last Post: 28th Nov 2011, 19:04 -
Changing AVI Bitrate!
By Ace-Of-Spades in forum Newbie / General discussionsReplies: 5Last Post: 8th May 2008, 11:23
