Hello
I have a problem after i have converted the video form XVID to VCD or SVCD.( also it's the same with AVI and DivX )
The video is sticky every 5/10 seconds?
Took out the sound with VDub to wav set at 44100Hz ( the sound is fine)..
TMPEGnc setting's ::Video-CD PAL (MPEG-1 352x288 25fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
The frame rate of the XVID: Aspect 640 x 272 (2.353 : 1)
Bitrate 926 kb/s
Frames/Sec 25.000 FPS
Thanks for any help![]()
The best way to predict the future is to invent it.
go here for details on how to PROPERLY check for and remove bad frames:
https://www.videohelp.com/forum/userguides/142555.php -
Ah, thank you. But, is there any other ways to edit/fix bad frames other than masking? For example, I have several anime .avi files with bad frames due to missing corrupted transfers, i.e., random blocks during scenes in the video. Is there a way to go in and "brush" the blocks away, or manually "photoshop" it out or something along those lines?
I would imagine something like Adobe Premiere or Sonic Foundry Vegas could perhaps help, but are there any simpler ways, any freeware methods, any tutorials/threads to recommend?
Thanks in advance.
"Tell me, I will forget, show me, I may remember, but involve me and I'll understand."
Conversion Problem
By Myrdivar in forum Video ConversionReplies: 3Last Post: 2nd Jun 2011, 05:44 -
conversion problem
By thomeski in forum Authoring (DVD)Replies: 2Last Post: 25th Apr 2010, 21:45 -
Replacement for TMPEGnc DVD Author for the Mac?
By The Monkees in forum MacReplies: 1Last Post: 24th Feb 2009, 14:36 -
Help conversion problem!
By milney100 in forum Video ConversionReplies: 6Last Post: 11th Jun 2008, 06:51 -
AVI File Not Supported by TMPEGnc?
By The Monkees in forum Video ConversionReplies: 5Last Post: 3rd Feb 2008, 19:26
