Hi, what I'm trying to do is edit my fight scene using slo-motion effects. I want the kick to be in slo-motion and then when I hit the guy it goes back to regular motion. I have tried to do it by using the razor to cut the one move I want, then I would change speed of that cut. But the results are very skippy/jumpy video and not a smooth transition between the speeds. Is there another way to do this and make it look really good? Thanks
the reason it's jumpy is that in slowing down the frame rate... damn, it's harder to explain than I thought.
Lets say you have 10 frames (1/3 of a second of video).
You want those 10 frames to stretch out for 2 seconds (60 frames).
So your software is duplicating frame 1 6 times, frame 2 6 times, etc.
Films like the Matrix (or any film that uses slow-motion stuff) is actually cranking up the frame rate of thier film - instead of 30fps, they will shoot at 90fps or 120fps, so they can slow down the film by a factor of 3 or 4 and retain smooth motion.
There is a piece of software called ReTimer, from RealViz, it will take your 10 frame segment and instead of just duplicating frame 1 6 times, it will insert 6 morphing frames between frames 1 and 2, then 6 morphing frames between 2 and 3, etc. etc. - so you have the illusion of continuous motion.
But it's pretty expensive - the last time I checked it out, it was over $1,000 easily...- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
here's a clip i did awhile ago of my son jumping a ramp. lacking the processor speed (athlon K-6 350mhz) to run Premiere, not to mention the $$$, i took the poor mans route and used Virtualdub and frameserved to Tmpgenc.
hitechjunkie -
can you give us a little more detail on how you did it?- housepig
Housepig Records
out now:
very easy in vegas -- maybe this tutorial will help you if you want to use adobe
http://www.creativecow.net/articles/kumar_satish/vegas_morph/index.htm
above is for creating bullet-time effects in vegas
in vegas you use velocity envolopes for speed effects and supersampling -- excellent results
i suspect some of the same methods can apply -
Originally Posted by housepig
1) captured the video to my PC, 30fps, 352x480, 2 interlaced fields per frame
2) loaded the AVI into VDub, with "each field a frame, double framerate" option (now 60fps framerate, 352x240 rez)
3) added the "field shift" filter to smooth out playback
4) frameserved to TMPGEnc, first part at 60fps framerate, second part at 15fps framerate (maybe even 10fps)
crude, but effective...
Getting 120fps to render in slo-mo
By simonov in forum EditingReplies: 4Last Post: 16th Dec 2011, 21:08 -
best motion search option to increase encoding speed while keeping quality?
By visualhippocracy in forum Video ConversionReplies: 4Last Post: 13th Jan 2011, 10:40 -
best speed to shoot to get slight slow-motion effect in music video?
By Cumie Music in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2010, 23:58 -
How edit a clip to play @ 1/2 speed (slow motion) in Vegas 8 plt.
By Jensen in forum EditingReplies: 7Last Post: 12th Feb 2008, 12:23 -
Motion type blur in premiere
By PharmBoy in forum EditingReplies: 0Last Post: 11th Jul 2007, 19:03
