I'm just trying to convert an AVI to an MPEG file.
I did a search with "P3Package.dll" in it and found posts that just re-downloading TMPGEnc solved the problem of that error message.
But when I just now downloaded it again, STILL get the error message.
What can I do to get rid of that error and make TMPGEnc work.
(I own the pay...PLUS version)
"Signature"......
I use a Dazzle capturing system that Only lets me capture into Mpeg. So that is all I work with. I never do any DV/AVI video..... -
Make sure when you uninstall TMPGEnc that you get all remnants of it (file search for TMPGE,Pegasys etc). Then reinstall.
"Today is only yesterdays tomorrow" -
I had a very simular problem, go to enviromental setting (under options), then click on the AVAPI plug in tab. Right click on the Directshow multimeda file reader and give it a higer priority. 2 would be the best.
Virtualdub Error Message - Failed to load FFmpeg.dll
By SOSmkII in forum Video ConversionReplies: 5Last Post: 6th Feb 2012, 08:14 -
I get a "could not load codec settings" with Fairuse Wizard
By felix in forum DVD RippingReplies: 3Last Post: 29th Apr 2011, 12:10 -
software to "load" DVD
By AlanHK in forum DVD & Blu-ray WritersReplies: 11Last Post: 17th Apr 2010, 08:07 -
Cant Play / Load A RAW DV file "Codec Status Undetermined" Please
By hypnoticpimp in forum Newbie / General discussionsReplies: 4Last Post: 30th Mar 2009, 15:29 -
TMPGenc DVD Author 3 issues "No stream available" Error Code 0x80
By newsletters in forum Video ConversionReplies: 0Last Post: 8th Oct 2007, 18:20
