Quick question guys - I've tried looking at some of the guides but I think I've missed something.
I've done a few backups of DVD-5 with DVD Decrypter - works fine.
Problem is with DVD-9 disks - have I got the following right?
1.) Rip main movie vobs to HDD with DVD Decrypter.
2.) Put all the files in a Video_ts folder.
3.) Burn video_ts folder using Recordnow Max.
Thanks in advance for any guidance.
A DVD-9 cannot fit on a blank DVD, you have the first part right. The second step is to send it through DVD Shrink or something like it to make the movie small enough to fit on a blank DVD. I use DVD2ONE. Then use Record Now to burn to DVD.
GOOD LUCK,
SLICK RICK
Originally Posted by lordsmurf -
The reason I said DVD Shrink was because it is free, if you want it Click Here
Here is a DVD Shrink Guide
SLICK RICK
DVD2One
Instant Copy 7
DVDShrink
DVD95Copy
does the job (they are in order I use them) DVD2one make a good job for most movies, Instant COpy 7 made the job for longer movie.
Take a look at the store, I found Instant copy for 9.99$ on a sale day ! -
Sorry I didn't explain myself properly.
I have a DVD-9 dvd that is less than 4.38Gb when I have the vob files that I want (the main movie). What I need to check is what to do next.
I have ripped these files to my HDD. Do I need to put them in a video_ts folder and then burn that folder with recordnow max or do I need to do something else to the files first?
thanks. -
If you have a ripped the movie from a dvd-9 disk and it is 4.37 gigs or less, you will have to just run it through IFOEdit. This program will create new ifo files so it will play correctly on your dvd player. I beleive you will have to also rip the main ifo file on the original dvd. There are may ifo gudies on this site.
I don't use IFOEdit anymore. I just run it through dvd2one and let it create the ifo files (it doesn't reencode if it doesn't need too and it is faster that ifo edit).
coot,
I have done this already on a DVD-9 where the main movie is under 4.37gig.
I use DVDToolBox to "extract" the main movie for a full DVD rip. I then use Nero to burn it. DVDToolBox creates your ifo files and such.
How to rip a copy protected VCD and then burn to a CD
By c1steady in forum Authoring (VCD/SVCD)Replies: 4Last Post: 17th Jul 2009, 14:11 -
By c1steady in forum Newbie / General discussionsReplies: 3Last Post: 17th Jul 2009, 06:40 -
Free Windows Programs for Rip/Burn
By pianoman1976 in forum Newbie / General discussionsReplies: 5Last Post: 29th Jan 2009, 22:30 -
Rip HDDVD then burn it on BD-RE: possible?
By fakerst in forum DVD RippingReplies: 3Last Post: 13th Dec 2007, 16:29 -
2 disc movie to RIP and Burn
By naftalim in forum Newbie / General discussionsReplies: 2Last Post: 11th Dec 2007, 12:44
