Can someone help me please when converting a AVI file to an mpeg2 compliant DVD some of the scenes seem to jitter but not if you play the file by itself oly after it's been encoded anyone got any suggestions?
probably not your problem but
I ripped a dvd to avi(using divx codec) and the avi was perfect but the mpeg encode was blocky and had flashing colours at times. I eventually discovered that this was because my dvd player was set to multi output rather than direct region output. If it is this problem set your dvd player to ntsc for an ntsc dvd and pal for a pal one.
This might also result if you are converting a film that is in one format to another, eg if ripping an ntsc film make sure it is set to ntsc in the source/format dialogue
hope this helps
scattergun
Problem With TMPGEnc
By Halibut72 in forum Video ConversionReplies: 2Last Post: 1st Oct 2008, 11:38 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 14:38 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 15:58 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 15:46
