Hi, I have been using TMPGenc for a while now, but its just started with a little bug. When I do a batch encode it will only encode the first project and then shutdown the program.
Any ideas?
Thanks Doot
I used to have the exact same problem and the above remedied it.
Tried the uninstall and reinstall but TMPGenc still shuts down after encoding one movie.
I'm having the same problem. It started when I switched to a dual processor Win XP system from a Uni Win98SE. I've tried the uninstall and delete, but to no avail. Did you have to go wipe registry entries too?
In batch encoding there is a button "Shutdown after encoding" ... may be that's the reason ????
no its not the shutdown option. That should shutdown my entire system after encoding *everything*. And its not checked. With this problem the program terminates just after the first batch encoding job is finished.
I've got a test run going now where I set the stop frame manually, instead of going the full file.
TMPGenc 4.0 XPress Question
By spliffy in forum Video ConversionReplies: 1Last Post: 19th Oct 2009, 18:04 -
TmpgEnc 4 XPress Question
By VEBouto in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jul 2009, 20:36 -
TMPGENC question
By triumph2004 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Aug 2008, 00:21 -
TMPGEnc question.
By Hal05154 in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2007, 09:20 -
TMPGEnc Question
By dafoe in forum EditingReplies: 5Last Post: 12th Oct 2007, 05:38
