I have two vcd's and i want to combine and convert them to one dvd...how do i do it???
VCD uses a valid DVD resolution, so no editing of the video stream is necessary. You could possibly join them using the TMPGenc MPEG TOOLS option (under the FILE menu). You would then need to Demultiplex the joined MPEG's (specifically, split the audio off), resample it to 48Khz, and then multiplex them back together.
This assumes that both VCD's are the same framerate, and of course, resolution.
You could also simply demux the audio from both, resample, and author in a DVD authoring package that allows mutliple MPEG's. You would then either link the first MPEG to the second ( so the second begins playing automatically at the end of the first ), or link to them via MENU in the DVD Authoring software.Impossible to see the future is. The Dark Side clouds everything... -
djrumpy has correct as always(
), here are some vcd to dvd guides : https://www.videohelp.com/guides?tools=&madeby=&formatconversionselect=VCD+to+DVD&ossele...&search=Search
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 11:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 20:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Help with VCD to DVD
By bwheeler in forum Newbie / General discussionsReplies: 9Last Post: 28th Jun 2007, 03:25 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
