I have a recent problem with Virtual Dub that I didn't have before. I locate bad frames in a XviD avi, cut them out. I play the brief sequence before saving to make sure they're gone. Then I "Save as AVI". When I open the new file, the frames I cut out are still there. Does anyone know what gives? I have also been having codec blues. A buddy gives me Xvid's that he says plays fine but on my machine the audio leads the video by half a second.
Mark
If you're following this procedure, don't forget to Press Edit> then delete key to remove those bad frames. I know I've inadvertently forgotten that step a few times.
new version of virtualdub out today (may 20th) fixed some problems, bad frame detection and a few other bugs ... (many it seems) ..
suggest you get the new version plus whatever everyone else sugggested. -
I have triple checked my procedure now and am doing what I have done in the past. And like I said, I view it in in Vdub before I save as avi and it is okay.
M -
Make sure that direct stream copy is checked for video and audio. Maybe you were using full processing mode and forgot to change it.
I have just downloaded Vdub 1.5.3 as sugested and that has solved my problem. Thanks BJ_M
M
saving edited video
By zulubase in forum Newbie / General discussionsReplies: 5Last Post: 2nd Jun 2009, 21:48 -
Virtual Dub Mod Saving Problem
By cdgfx84 in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 14:08 -
MKV to AVI in Virtual Dub With AviSynth :?: :!:
By ineedhelp123 in forum Video ConversionReplies: 28Last Post: 21st Jul 2008, 16:08 -
virtual dub choppy avi
By bigwheels103 in forum Newbie / General discussionsReplies: 2Last Post: 24th Oct 2007, 21:27 -
AVI to DVD w/ Virtual Dub
By hawsonggook in forum Authoring (DVD)Replies: 1Last Post: 15th Jun 2007, 02:58
