I've burned a few VCDs using "The newbies guide to fitting a movie onto one cd using TMPGenc" from this site, with no problems whatsoever.
Now when I convert an avi. to mpg. theres no audio with the movie. There are no errors while converting, but when I play the converted file there's no audio to go with the video.
Does anyone know whats going on?
Any suggestions would be a great help.
the audio is most likely ac3. pop the file into gspot and see what it tells you.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Thanks for the advice.
I tried this method "Click on Option, Enviromental Setting, VFAPI Plug In. Change the priority of "DirectShow Multimedia File Reader to postion 1 or 2 by right clicking on it and setting the priority higher. You will see that it will move to the top."
But Ill keep gspot also, just in case.Have fun in the sun and get laid in the shade! -
i can help you. go to tools and get virtualdub. in virtual dub, select file and open your vidio file. go to the audio tab and make sure its set to source file and direct stream copy. now under file, select save wav... select a folder and hit ok. now under tmpgenc, select your vidio file and then manually select the audio wav file you just made. try this and let me know how it goes.
I had exactly the same prob last night, but being a pillock I never actually realised until I'd burnt it to DVD
Will this method work OK then D_Ran? Am I likely to run into any synch probs if I extract the audio from an NTSC AVI then convert that into PAL? I'm new to all this, so don't laugh too much if thats a stupid question! -
D-Ran, thanks a lot for the tip. It worked.
Thanks a lot! I had the same problem. I once tried using AVI to WAV and putting the WAV file with the video, but the sound became out of sync about 5 min in, and got worse!
I'll try the methods above and see what happens.
Thanks again.
Lou
Convert AVI to ? to TMPGEnc DVDAuthor with 5.1 audio
By NDMMackay in forum Video ConversionReplies: 2Last Post: 15th Oct 2011, 07:02 -
Convert mkv 6ch to mp4 2ch - audio problems
By newinvestor23 in forum Video ConversionReplies: 3Last Post: 22nd Jan 2010, 13:36 -
Newbie trying to convert using WinFF - audio sync problems
By bogey44 in forum Video ConversionReplies: 1Last Post: 1st Mar 2009, 08:08 -
How do I convert DVD movie to DIVX w/o Audio Syncs problems
By peggypwr1 in forum Video ConversionReplies: 10Last Post: 1st Aug 2008, 17:22 -
Does TMPGEnc DVD Source Creator 4 convert Divx(Avi) with audio?
By Plarocks in forum Authoring (DVD)Replies: 9Last Post: 10th Sep 2007, 17:11
