I keep reading about these templates so I downloaded one for SVCD. I was surprised that the template only encodes video. Why is that?
Most people view TMPGENC as not a very good tool for converting video so that would be my guess as why only video. Most people use BeSweet to convert their audio which is a pretty easy app to use. Of course, the person who can definitively answer is Kwag himself :P
TMPGEnc does has some problems with encoding audio. On some frequencies the audio can sound tinny. BeSweet and other programs can process audio much better than TMPGEnc.
But of course, you could have found all this out at Kwag's KVCD.net site where you first downloaded the template...!
I spent about an hour there reading the guides but I don't recall any mention of why the audio is encoded separately. Sorry!Originally Posted by ckdexterhn1
because some people just prefer using another program for the audio. you can use use tmpgenc for the audio if you want, though. so its not a video only template.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
I've never had any problems with the audio quality of TMPG, even with sample rate conversions, although I usually use Cool Edit Pro for those. Just remember that MP2 audio isn't as good quality as MP3 audio, so make sure you don't drop the bitrates below 192kbps.
Hi Michelle,Originally Posted by Michelle
There are basically two reasons.
(1) TMPEG's audio encoder is really crappy, unless you encode your audio >=192Kbps.
(2) If you have a Dolby Prologic II receiver, you won't be able to take advantage of "Surround 2" (AC3/DD5.1-->DS2) audio capability
In a short explanation, use HeadAC3he as your audio encoder, and even at 112Kbps audio encoded as surround 2, it will sound better that TMPEG's audio encoded at 192Kbps.
There's no way to get surround 2 sound with TMPEG's audio encoder. You either have to use HeadAC3he or BeSweet. My choice is always HeadAC3he, because it's much faster than BeSweet
Hope that helps
-kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net
Ready Made Templates/Projects for Video Editing SW
By ozab in forum EditingReplies: 5Last Post: 4th Nov 2012, 01:12 -
KVCD
By Bat21UK in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2007, 16:31 -
2 hours plus on one kvcd - how?
By t41 in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2007, 12:08 -
Xvid to KVCD
By mjaeson in forum Video ConversionReplies: 8Last Post: 25th May 2007, 21:05 -
KVCD to DVD
By buttzilla in forum Video ConversionReplies: 2Last Post: 6th May 2007, 09:01
