When I load audio, it says that the format is unsupported. I checked the version using AVICodec, and it says: "Audio : 0.0 b, 224 Kbps, 44100 Hz, 2 chan., 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported".
I've also tried ripping the audio to a .wav using VirtualDub, but I also get problems.
Any ideas?
Thanks,
Leigh
Where did you get that audio in the first place ? and does it play good in WinAMP ?
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Scan the file in gspot, I would guess that the file has ac3 audio, if so follow one of the guides on the left
Ok... here's exactly what's happening.
My DVD player doesn't play SVCDs, but it does play VCDs. So, a lot of the movies I get are SVCDs and come in bin/cue format. I use ISOBuster to extract the MPEG from the bin. Then I use TMPGEnc to encode it to VCD. But, when I load the MPEG into TMPGEnc, it says that the audio format is not supported. I also tried using VirtualDub to extract the audio from the MPEG and then use that WAV in TMPGEnc, but I couldn't extract the audio. Please help.
Thanks,
Leigh -
Ohhh!!! why didn't you just say so! you know how to use the DVD to VCD method ? well, skip the ripping, and go from the DVD2AVI step, and just load the MPG into DVD2AVI, and it will create the D2V and WAV for you and keep following the guide 8)
Best Regards,
Sefy Levy,
Problem loading Blu Ray files into TMPGEnc Authoring Works 4
By DSguardian in forum Blu-ray RippingReplies: 0Last Post: 14th Apr 2010, 19:52 -
Loading Problem on DVP5990 Player
By im-an-idiot in forum DVD & Blu-ray PlayersReplies: 6Last Post: 16th Sep 2009, 12:40 -
JVC DR-MH50S Loading Problem
By munish1000 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 5th Feb 2009, 07:36 -
Major problem loading audio from AVI file into Auto Gordian Knot v 2.45
By robo5050 in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2008, 06:12 -
Problem loading AC-3 audio (inside MPEG) in Premiere
By irving in forum EditingReplies: 2Last Post: 23rd May 2007, 09:25
