I compacted a video with about one hour using TMPGENC
When I try to create a DVD with Sonic DVDit, a mensage appears:
ERROR: VIDEO PICTURE SIZE LARGER THAN BUFFER.
What is happening?
If you have encoded DVD assets at 720x576 (PAL), or 720x480 (NTSC), then you should have set your VBV buffer size to 224 in TMPGEnc. I suspect that this is not the case with the settings you have used (perhaps you used a setting of 112?)
There's also some info on this issue here:
http://dvd-hq.info/Compression.html
Arky ;o) -
Thank you for attention.
I used the default controls. For DVD is 224.
Do you know another solution ?
MuxMan : Buffer Underflow
By Bonie81 in forum Authoring (DVD)Replies: 3Last Post: 23rd Oct 2011, 16:38 -
DVD Lab Pro Error: "Read data size is over the buffer limit"
By Motinha in forum Newbie / General discussionsReplies: 0Last Post: 29th Oct 2010, 03:49 -
ffmpeg gives buffer underflow
By zkab in forum Video ConversionReplies: 2Last Post: 9th Aug 2010, 04:45 -
YouTube Buffer Speed
By gooberguy in forum ComputerReplies: 4Last Post: 25th Feb 2010, 22:12 -
What is buffer size?
By dzsoul in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 10:04
