im trying to use nero 5 5 10 28 to burn a vcd our dvd players do not support svcd maybe i have a setting wrong i have a 460 mb avi i want to burn when i drag it to nero i end up with a 894 mb avi something is surly wrong please help
Use another program to convert the AVi to MPG1(i.e. TMPGENc), then just use Nero to create the VCD.
I was not very happy with the conversions that Nero does, TMPGENc allows me to tweek. -
I found that the converter with Nero was OK, I used it when I was first started making VCDs. If you have a low action video file, it's OK, but otherwise, andkiich is correct, go with TMPGEnc. After you've had a chance to play with the settings and get used to TMPGEnc, you'll wonder how you ever got along without it. If you still want to use Nero, make sure the box is checked when you are choosing the CD type (i.e. CDROM, VCD, etc.) that says "create standard compliant CD". Are you using the wizard in Nero?
"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
You did not mention how long your AVI file was in terms of playing time.
VCD (standard) works out at about 10Mb per minute (1150kbps for video, 224kbps for audio).
So assuming Nero encoded correctly, I am guessing your AVI was somewhere around 89 minutes long? If that is the case, Nero did the right thing, and any other program will do the same if it is creating a compliant VCD file.
Perhaps this is your problem.The glass is neither half-full, nor half-empty.
It is simply twice as big as it needs to be.
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 21:09 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:10 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 05:06
