Hi all
Larry here.
My question is as follows.
how can i put .wav files onto a dvdr and have it compatable with my dvd player.
nero 5.5 does not have an option for a dvd audio disk and when i try the cd audio option it wont work because its a dvdr and not a cdr.
i assume i will have to convert the .wav files into 2 channel ac3 or pcm format. I presume pcm format will have less compression?.
can anyone tell me what programmes i will need to get the .wav files converted into a format that can play on a standalone dvd player. and once converted weather i can just simply use nero 5.5 dvd-rom setting to simply write the files to disk.
Thanks in-advance for your help
Larry.
you could use this software http://www.minnetonkaaudio.com/A_plus_features_3.htm
or just create a low bit rate mpeg2 file of nothing (black) the lenth of your wav files and make a dvd with it and your wave files ..
VOB & MPEG4 HD to Windows Media Compatable Format (DVD Quality?)
By RobsterNo1 in forum Video ConversionReplies: 2Last Post: 28th Oct 2008, 07:49 -
what is best and multi video fomat
By jaggalink in forum Video ConversionReplies: 1Last Post: 2nd May 2008, 09:03 -
DVD Audio To .wav Sample Rate Question
By xtreme469 in forum AudioReplies: 3Last Post: 29th Sep 2007, 10:04 -
movie with Xivd fomat!!!
By dewolf in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 20:55 -
Newbee and newbee question firwire quality
By saligari in forum Newbie / General discussionsReplies: 0Last Post: 12th Jul 2007, 07:50
