After using IFOedit to remove some vob ID, I got this error from Instant Copy 7:
Index Out of bond (4)
what is this ?
thanks
EDIT: I think I found the problem. DVD2one also crach.
On the DVD, I have an extra that have 2 vobs. First one is of curse 1gig and the second one 10meg (vts_xx_01 and 02) When I tell IFOedit to remvoe the extra and keep the 1second flash, it does only 1 vob at about 200k.. the second vobs is still the same..
Deleting the second vob didn't help.
HELP !
I've normally noticed the number in the brackets is normally the number of errors that are being referred too in the IFO that are missing or incorrect
I understand that...
But the question is: How to rip an Extra of more than 1 vob ? (more than 1gig) ? -
just read thread again to try to understand yout problem
If I'm right in thinking on this is what you are trying to do
when you strip VOB ID 1 out and leave just VOB ID 2 in (0.xx sec) then you should be able to remove the 2 VOBS (VTS_xx_1.VOB & VTS_xx_2.VOB) and insert the new VTS_xx_1.VOB and replace the 4 other files
these are the 5 new files
VIDEO_TS.IFO
VIDEO_TS.BUP
VTS_xx_0.IFO
VTS_xx_0.BUP
VTS_xx_1.VOB
and all shud be fine
how it wasn't I do not know -
you understand my problem MackemX.. I did what you sayd, and got error in DVD2one and IC7..
Open the IFO of the extra
Keeping only ID2
Deleting old vob (both)
Replacing all the files IFOedit made
Testing in Power DVD sucessfull
IC7 crach and DVD2one can't make VIDEO_TS files...
I'm not really good in all those thing.. but I was able to remove extra's that are on 1 single vob, but not multiple vobs
I need IFOedit for Mac
By bryceguy in forum MacReplies: 7Last Post: 14th Dec 2011, 11:45 -
Usinf IFOEdit to correct an error in authoring
By netmask56 in forum Authoring (DVD)Replies: 3Last Post: 30th Nov 2007, 22:30 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
IFOedit question...
By Djard in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2007, 00:42 -
adding CC with ifoedit
By loster in forum Authoring (DVD)Replies: 0Last Post: 9th May 2007, 19:15
