Poll: What size is the tv you watch your DVDr's on?
Be advised that this is a public poll: other users can see the choice(s) you selected.
  1. What size is the tv you play your captures on, and what resolution do you us? (Must be DVD Compliant)
    I'm just wondering because, I watch my DVDr's on a 27" screen with a capture size of 720x480 and I want to know if 352x480 captures will look good on that size of a tv...
    May 2003
    Mission Viejo, CA
    I capture in 352x480 @ 4000BR from digital cable box via S-video cable. Can't tell the difference from watching the live feed on my 32" set.
  3. Human j1d10t's Avatar
    Feb 2003
    California, USA
    I capture at 640x480, then downsize to 352x480 and (depending on the show) they look just the same as they do watching them live on my 51inch Sony HDTV. Sometimes they look better than my digital cable does.
    "Don't try to be a great man. Just be a man, and let history make its own judgment."
    Zefram Cochrane
    2073
