I would really like to know what is better? Burning from bin/cue or burning from the mpeg file?
Is one better than the other? If so what one and why??
Thanks to anyone who can clear this up!!
If by "burning from the mpeg file" you mean "burning a data CD with the MPEG on it", then that isn't a VCD/SVCD and most set-top players won't play it. You also will only get 700MB on your 80-minute disc instead of 800 like you do when you burn a VCD/SVCD.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
