That's it. I would want to know how I can rip a concert DVD to a music CD, I just want to listen to the music so I can play it on my audio car cd player.
Hi Pavlom. Asuggestion would be to:
1. Rip DVD using Smartripper or Decryptor
2. Use DVD2AVI to generate wav file by using Dolby Decode and 48 > 44.1khz setting.
3. Burn using your CD music software.
An alternative to last to steps are:
2. Use DVD2AVI to generate AC3 file using Demux setting leave 48Khz > 44.1khz unticked.
3. Use Headac3he with settings:- wav destination
44.1khz downsample
Surround2
CBR
128kb/s
The latter will also give Dolby Surround if you got a sound system at home. Music will be in a long track. If you want to split tracks there is plenty of wav splitters around.Love makes the world go round - wav destination
Thanks jeffoz1. I will try to do the steps you specified and I'll let you know the results.
and ifyou dont want one 80 minute long track you can split it up using sound forge.
Ripping Music Videos From DVD
By skywalka in forum DVD RippingReplies: 15Last Post: 17th Apr 2012, 12:27 -
Ripping Music Videos From WTV - DVR-MS - MPEG?
By skywalka in forum EditingReplies: 5Last Post: 12th Jan 2011, 03:13 -
Ripping a portion from a music file
By Shadowofthedarkgod in forum AudioReplies: 7Last Post: 17th Jul 2008, 15:09 -
VHS Concert to DVD
By Jelleke in forum RestorationReplies: 6Last Post: 11th Sep 2007, 02:40
