Whenever i encode a avi(divx) file to mpeg2 for dvd i get alot of pixlization during sceens that are dark of have alot of black in them. Is there a setting that will help get rid of them. Here are the setting i curently use.
Rate control = 2pass vbr
DC component persision = 10 bit
Motion Search = High quialty
gop = only detect sceen change checked
Quantize matrix = MPEG Standard
Output YUV data as Basic YCbCr not CCIR601
Use floating point DCT
any suggestions?
Increase the bitrate.
Lower the resolution.
And remember, garbage in garbage out....and divx has usually problem with areas with same colors(check backgrounds walls with same color and you often see pixelations).
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 12:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 16:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43
