  1. i need to replace a folder in my bin file with one on my HD. how do i do this???
  2. Member adam's Avatar
    Sep 2000
    You can't modify a bin image, you have to extract it then recompile it with the new files.
    CDMage is a good bin extractor.
    Another option is to mount the image with Deamon tools and then you can just drag and drop the files from the image onto your hard drive.
    From there you can make a new image with CDRWin or you can just reburn the files directly with just about any burning software.
  3. Use WinISO.
    It's a program for editing all kinds of ISO files.
    Very good.
    This is a block of text that can be added to posts you make. There is a 255 character limit
  4. thanks a lot you guys. i just installed the game and then relpaced the file.
