How do i make a AVI file, no sound, from a VOB file, i opened it and cropped it, and put dont process audio, but when i go to save avi, i get 0KB for the file??
"Say Goodnight to the bad guy....... comon... it's the last time your gonna see a bad guy lik dis again..." - Tony Montana aka SCARFACE
What program are you using? Sounds like you may be actually setting up a frameserve or temp .avi file.
DVD2AVI doesn't ACTUALLY do what the name implies.....I just use it for frameserving.
Myself, I rip the vobs using CladDVD which will automatically create a file (if the option is checked) that you can frameserve to TMPGENC or Virtualdub through DVD2AVI that's included in the CladDVD package.
This place taugh me a lot:
http://www.clonead.pwp.blueyonder.co.uk/claddvduserguide.htm
http://www.clonead.pwp.blueyonder.co.uk/converttoavi.htm
The MAIN site:
http://www.clonead.co.uk/
Good luck!!
-Nate -
thanks, but i just need a program to make an AVI File from a VOB, i dont need MPEG/VCD
"Say Goodnight to the bad guy....... comon... it's the last time your gonna see a bad guy lik dis again..." - Tony Montana aka SCARFACE -
there we go, virtualdub worked out fine
question about avi files
By tlrbjc in forum Newbie / General discussionsReplies: 5Last Post: 17th Jul 2009, 13:54 -
VOB to avi question
By nalooti in forum Video ConversionReplies: 2Last Post: 3rd Jul 2009, 17:16 -
For VOB files to AVI, I use avi.net . . Question
By nhbfan12345 in forum DVD RippingReplies: 4Last Post: 10th Sep 2008, 23:02 -
AVI ---> DVD question
By arcticmoonshadow in forum Newbie / General discussionsReplies: 2Last Post: 2nd Mar 2008, 21:40 -
AVI file question
By jImMy_JaZz in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2008, 15:03
