Is there a fast way to extract files from a bunch of folders into one folder.
I have font folio but all the fonts r in different folders n it'll take forever to install then.
There's no installer.
You can do this using the 'Search' tool in Windows.
• Select 'Start' -> 'Search' -> 'For Files of Folders'.
• In the 'Search for files or folders named:' box just enter *.* or maybe you just need *.fnt
• In the 'Look in:' box, select 'browse' and select the parent directory of where all the font directories reside.
• Hit the 'Search Now' button and all the directories and their files will be listed.
• Click on the 'Name' column to sort the list by name.
• Now select all the font files (don't select any directories) and press CTRL/C to copy them.
• In windows explorer go to the directory that you want to copy them to and just 'paste' (CTRL/V) them into it.
Extract all frames from video files
By nic3 in forum EditingReplies: 6Last Post: 25th Dec 2016, 15:21 -
How to Extract Subtitles from ratDVD Files?
By devilcoelhodog in forum Newbie / General discussionsReplies: 3Last Post: 23rd Feb 2009, 07:24 -
extract .iso files
By avextraxjp in forum Newbie / General discussionsReplies: 8Last Post: 1st Jun 2008, 01:49 -
I need to extract photo files from DVD
By tejana in forum MacReplies: 4Last Post: 17th Aug 2007, 16:31 -
How to extract hardsubs from .avi files?
By kehn in forum SubtitleReplies: 4Last Post: 25th Jul 2007, 07:30
