Ok I downloaded a movie off the net that was two files, but the two files are each too big to burn onto vcd. So i want to put them together and then re-cut the one big file into three so i can burn them. What program is good for this? Or any suggestions to get the original two on just two
cd-rs would help. THX 4 any help.
"What ain't no country i ever heard of. They speak english in what?
Are these mpegs? If so, then the standard maximum capacity for an 80 min. CD is 800Mb as a VCD. You can cut/join them if necessary using TMPGEnc, there's a guide in the Edit section.
"Art is making something out of nothing and selling it." - Frank Zappa -
Right, thanks i'll try. But the cds i have say 80 min. 700mb. Does the descrepancy in the mbs make a difference
"What ain't no country i ever heard of. They speak english in what? -
If you make a VCD you can get up to 800 mb on a 700mb cdr.
If you still want to join the AVI's you can use VIRTUALDUB.
You could also try making a XVCD which may suit your needs using 2 cdr's."Today is only yesterdays tomorrow" -
Ok thx i'll try it and report back
Splitting/cutting/joining MP4 accurately...
By The.King in forum EditingReplies: 2Last Post: 2nd Nov 2011, 13:35 -
need help cutting and joining avi files in virtualdub
By granturissimus in forum EditingReplies: 3Last Post: 31st Jan 2011, 03:53 -
Easiest software for compilation, cutting/joining?
By jiopi in forum EditingReplies: 0Last Post: 14th Oct 2010, 13:31 -
Simple MPEG2 Cutting/Joining Question
By thefiddler in forum EditingReplies: 4Last Post: 21st Dec 2009, 16:39 -
WMV cutting-joining-playback problems
By Cusem in forum EditingReplies: 2Last Post: 7th Dec 2007, 04:48
