i don't know how to ask this but here goes..how does one get past the fat32 limitations in win/98..i use super 1394 to capture and when i download from my digi camcorder, it cuts out after about 20 minutes..i then have to start the capture again..any suggestions..thank to u all and i think this is a great forum..
FAT32 has limit of 4GB for the files you create or save.
The only easy way to overcome the limit is to upgrade to NTFS, that means, to upgrade to Windows 2000 Pro or Windows XP.
I'd recommend Win2K thou. -
I'm not familar with your software but some capturing programs have a 'spill system' that will spilt your capture into several < 4GB files (eg. AVI_IO and VitrualDub).
I did this for a while (then frameserved with avisynth). But if you're going to be working with digitial video you really should step up to NTFS. Makes life much easier (esp if you decide to start burning/ripping/generating DVD image files).
Converting FAT memory stick to NTFS
By SE14man in forum Newbie / General discussionsReplies: 7Last Post: 15th Oct 2011, 01:47 -
FAT+ troubles with .mkv merged files
By fabpozzi in forum Media Center PC / MediaCentersReplies: 2Last Post: 19th Jan 2011, 11:29 -
Subs fat and blurred on VOBs on my Hard disk, Not on DVD
By stumerr in forum Newbie / General discussionsReplies: 4Last Post: 20th Jun 2010, 00:17 -
Security bits in FAT & NTFS?
By G)-(OST in forum ComputerReplies: 9Last Post: 22nd Aug 2009, 15:16 -
FAT to NTFS
By hardy in forum ComputerReplies: 13Last Post: 24th Jun 2009, 16:24
