When i try to play (from virtualdub) an avi captured with virtualdub i get this message "VideoSourceAVI: uncompressed frame is short (expected 335232 bytes, got 22348"...with other programs them just crash.
I capture the avi with both audio and video uncompressed, 24bit, 384x288 as usual.
Also with other programs the captured avi files results broken. Instead capturing with windows media encoder (asf format) works fine. So seems like that I have some problem capturing in avi format.
Something should be changed in my system, some times ago i don't had this problem.
All this stuff under win2000, sp2, dx8, vb1.4.7, ecc..
Any idea?
Thanks a lot
Results 1 to 1 of 1
AnonymousGuest
Resizing(Frame Size) w/ VIRTUALDUB - PLEASE HELP!!!
By MDrumm in forum EditingReplies: 8Last Post: 17th Jan 2011, 03:12 -
Exporting from uncompressed AVI to uncompressed MOV
By courtneye in forum Video ConversionReplies: 0Last Post: 9th Jul 2010, 09:20 -
configure XVID so virtualdub key I-frame's is able to go 1,2,3,4,...?
By Ghtpua in forum EditingReplies: 0Last Post: 21st Oct 2007, 15:05 -
increase the frame width with virtualdub?
By sharmine in forum Video ConversionReplies: 3Last Post: 17th Sep 2007, 18:17 -
Virtualdub: the key frame displayed is off
By cheerful in forum Newbie / General discussionsReplies: 11Last Post: 19th Jun 2007, 13:28
