I have an NEC DVD+RW drive which should be compatible with RecordNow Max. However, when I try to run it, the program is telling me it doesn't recogniza any compatible drives. I have a Dell system, already came with EasyCD Creator installed, does this matter? The RecordNow Max is a trial version. Any help would be appreciated.
probaly, try uninstalling your other burning programs, then reinstall recordnow.
Try running the engine update. This adds many new burners.
Greetz,
pSyChO dAdThe difference between genius and insanity is only measured by success ! -
Roxio doesn't work with any other software. Nero doesn't like it at all. The problem comes from the packet writing software it uses for C/DVDRW. I'd un-install it completely, then re-install recodnow.
To Be, Or, Not To Be, That, Is The Gazorgan Plan
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2010, 00:35 -
Easy MKV -> DVD application? Want 5.1 and max quality (4,4 GB or DVD9)
By bjorsa in forum Newbie / General discussionsReplies: 19Last Post: 3rd May 2010, 13:08 -
Sony Video Capture 6 (Vegas MS) hard drive max size limit?
By distendo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Jun 2008, 10:02 -
Free and easy drive backup/restore software
By pcspeak in forum ComputerReplies: 4Last Post: 8th Jun 2008, 00:10 -
Guide to fix Illegal Disc Error for NEC drive (possibly others)
By lucaschrist in forum DVD & Blu-ray WritersReplies: 10Last Post: 5th Apr 2008, 02:11
