  1. Ok, I encoded my first DiVX movie, but want to know I could have done any better. I have almost every video and audio codec, but I ended up installing Kristal Studio 4.33 pack with all those codecs. For all the people who convert DVD's to DiVX, what is your best result. Please be specific like what codec exactly the key frame, everything! I used Flask because I'm a newbie, but need to know details to get great clarity but getting a reasonable video size.
    May 2001
    Ramstein, Germany
    Use the divix 4 beta codec it has the best results so far that I have seen. Oh and dont use flask mpeg.
    Sep 2000
    Ga Usa
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    hmm.. then what program to use for dvd to divx? and also i was wondering if anyone knew how to put chapters in avi's (divx)?
  4. Try Smartripper to generate vobs
    DVD2AVI ---> d2v file and wav file
    TMPGenc to generate Divx using divx 4 codec
    Sep 2000
    Ga Usa
    what? Tmpg can't make divx, it makes vcds(xvcds,Svcds,SXvcds,ect.).
  6. sulfur
    Your wrong....tmpgenc can make avi divx files..and very good ones too.
    check things out properly first before you reply !
    regards
