sometimes when i convert an avi file to vcd, tmpgenc for some reason encodes the mpeg fine but instead of stopping encoding at the end of the film, it encodes the film followed by a black screen for like 2hrs!!?? so the resulting file is huge and when u watch it the movie is fine but there is a black screen encoded after it!! any ideas why it is doing this?? any help would be grateful...thnx
www.dvdrhelp.com/tmpgenc#problems
"If TMPGEnc says that the video time / runtime is way too long
Try change the directshow reader priority, in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 or to the top of plugin-list and reopen the video. If that doesn't help you can always use the source range to select exact what to encode, under Settings->Advanced in tmpgenc."
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 10:32 -
A hardware prob, but what?
By ahhaa in forum ComputerReplies: 3Last Post: 22nd Sep 2009, 22:00 -
Wireless prob?
By Immortal25 in forum ComputerReplies: 4Last Post: 3rd Jun 2009, 08:55 -
gc prob
By Mr anderson in forum ComputerReplies: 6Last Post: 10th Sep 2007, 06:33 -
MPEG DV prob
By mainegate in forum ffmpegX general discussionReplies: 0Last Post: 24th Aug 2007, 18:01
