Just a small thing but IMO worth mentioning.
If I forget to log in (as I often do) and find a post I want to post on and then log in I get taken back to the forum index.
Would it be possible to be given a choice, or just simply taken back to where you came from, ie last post viewed?
Just a small thing I know but like I say, worth a mention
Will
tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
Weird, I go to the post I was replying to. I'm running IE 6.0.2800.1106 SP1 and assorted security patches, W2K SP3. I also have Dbugging enabled, but never get any problem pages here.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
If I'm logged in first I get sent back to the last post, but not if I log in after I view a post.
Is that the same for you?
I know the answer is to check the box which automatically logs you on each time but when I'm at work this doesn't work (some server shit).
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Instead of going to the login page just hit reply or new topic and the login page will appear...now should you be redicted direclty to the reply or new topic page.
Okey-dokey
W.tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
Suggestion to Web Master
By rcubed in forum FeedbackReplies: 0Last Post: 3rd Aug 2011, 16:29 -
HD Mini DV camera suggestion?
By alange5 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 14th Jul 2011, 12:51 -
Multicore suggestion?
By pardu in forum LinuxReplies: 18Last Post: 27th Jun 2010, 19:18 -
Suggestion for video decompiler...
By Starkian in forum EditingReplies: 2Last Post: 24th Aug 2008, 05:29 -
DVD Recorder Suggestion
By mis3 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 10th Feb 2008, 13:04
