this advice is driving me a little crazy:
1.) when i "lock" the audio doing PAL or NTSC capturing
SVHS vcr (svhs out for image) -> (svhs in) CANOPUS ADVC-100 -> firewire -> pc (scenalyzer)
i often get audio gaps which are totally unwanted. so....doing capturing in "unlocked" mode (= switch 3 "ON") everything's fine....i wonder why is that ? doesnt make sense at all, does it ?
2.) besides that i would like to know if you have made some experience in capturing old bad VHS which turn out in "jumping image" like a vhs being forwarded for a very short time in my DV AVI file using the mentioned capturing ? stablizer needed ? are there devices you could recommend for bad vhs ?
any help appreciated!
re problem #2:
If you have a poor video source you can defeat the MACROVISION default by holding down the INPUT selection on the top left of the box for about 20 seconds or so. Depending on your applications, you may see a colorbars image at first, just keep holding the input down until they disappear. This may help with the jumpy video problem. (not to mention other things)
Be aware that if the video source is poor you will probably have some audio problems despite the audio lock. (poor sync, garbling, volume drops) Not CANOPUS' problem.
ADVC100 is still the best afforable thing out there for amateurs.
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 19:26 -
Canopus ADVC-100 - noisey/grainy and scaling?
By Gibson's Squares in forum Capturing and VCRReplies: 4Last Post: 2nd Jun 2011, 15:41 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
Microsoft DV Camera and VCR/ Canopus ADVC 100
By BonnieW88 in forum Capturing and VCRReplies: 0Last Post: 27th Feb 2010, 18:26 -
Canopus ADVC-100 outputs
By datman in forum Capturing and VCRReplies: 2Last Post: 7th May 2007, 19:24
