    Dec 2002
    I was looking to purchase a Pioneer DVR AO5 and decided to look at the ratings first. Was kind of alarmed to see the ratings were off a bit until I started reading them. MANY of them were just comments with no rating at all and made the overall rating fall !. What I would propose is the the rating itself be the key to inclusion. If you fail to enter a rating the post would not be accepted but would take you back to that entry until you entered one or deleted your comment. This, I think, would result in a more meaningful and accurate rating system and would be very easy to incorporate. And, accuracy is what we is huntin' fer. Ha! Thanks
    No rating comments are not included in the average, it is the total votes that is wrong(it is same as total comments). I will try and fix it.
    Fixed now. The total votes is after the rate like 8.7(34 votes) and it can be different from total comments.
    Thanks.
