cheers nomax
get it HERE
Code:What is new in this version 7.1.1: The main improvements are a significant speed increase for the DVD transcoding (approx. 30%-50% faster) and a new analyze method for better target disk size usage. Various registry settings were added. For more information, please report to our support Knowledge Base. Key combinations (no support available for this function) F5 : Enable the OK button ignoring all size issues F6 : Saves the currently selected percentages/titles/streams for this DVD F7 : Load (if previously saved) settings for this DVD Batch Processing functionnality. For more information, please report to our support Knowledge Base
I also noticed a new reg settings on this page HERE
DVDVideoSaveBorder is interesting cos it looks like a black bar issue, trying it on Road To Perdition nowDWORD: DVDDestSize Default: 4424
Size InstantCopy tries to reach for the destination medium in MB
DWORD: DVDDestDisplaySize Default: 4424
Size InstantCopy uses to determine if the contents of the disc
fit or wont fit on a recordable disc in MB
DWORD: DVDVideoSaveBorder Default: 2
Unsecurity in percent of the transcoding process [/B]
p.s. LOL
"Phantom cell sets" fixed , like the quotes round Phantom Pinnacle, whatever gave you that idea?
still no fix on the sizing issue even after playing with the DVDVideoSaveBorder setting
increasing it resulted in a smaller size
early tests tho, so maybe someone will suss it or Pinnacle will explain what it means -
the sizing is still the same old crap
so much for the better sizing results cos it still undersizes big style
most DVD'S will result in 4.2 if set to 4.56 with the old version, the trick is getting it to produce 4.37Gb and this latest version doesn't make it any easier even with the new reg settings
shame, maybe next time -
I always keep a 100meg free on the DVD to be safe.. so 4.2Gig is perfect for me (anyway not much difference) So I will still ask for 4.56gig filesOriginally Posted by MackemX
does the encode is faster ? is yes how much ?
EDIT: Strange.. I try to install the Patch, and the setup tell me he can not find IC7 installed.. I reinstalled IC7, still have te same problem...
Where may I get the last version of the x264 - 64 bits version codec?
By daniel827 in forum EditingReplies: 5Last Post: 27th Dec 2011, 19:55 -
Mac version of VLC is less functional than the Windows and Linux version
By HitTheRoad in forum MacReplies: 12Last Post: 30th Oct 2011, 04:48 -
SUPER version 39 is broken - reinstall older version?
By castalla in forum Video ConversionReplies: 7Last Post: 3rd Nov 2010, 19:20 -
Is the 'academic version' different from the commercial version of Vegas 8?
By jbigfoot in forum Newbie / General discussionsReplies: 2Last Post: 16th Apr 2008, 01:19 -
where to download old version of dvd fab??? error in new version
By willhenderson in forum Newbie / General discussionsReplies: 1Last Post: 1st Dec 2007, 17:00
