I would like to convert DTS audio to 6 mono WAVs that I then can use to encode an AC3 stream. So I can get both DTS and AC3 audio on the same DVD instead of the original DTS and 2 channel PCM.
How can I do this?? does anyone know?
I have tried Hypercube , but I can not get it to work. is there any other way??
Using grafedit? but I only get one pin out from the Intervideo filter?
And BJ_M , please no comment like: Why do that and so on. I just want to do this conversion and do not need your opinions on the subject.
read this thread and see if this help you.
https://www.videohelp.com/forum/viewtopic.php?t=159480
5.1 wav or 6 mono wavs to 5.1 Ac3 conversion
By wturner in forum AudioReplies: 38Last Post: 24th Nov 2013, 08:26 -
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 13:36 -
DTS-ES 6.1 to 7 mono WAVs
By Zetski210 in forum AudioReplies: 16Last Post: 28th Nov 2010, 01:13 -
How do I extract eac3 dd+ audio to mono wavs?
By yoda313 in forum AudioReplies: 15Last Post: 14th Feb 2009, 18:22 -
SixWAV2AC3 mono wavs files ENCODER
By arturjose in forum AudioReplies: 8Last Post: 19th Sep 2007, 00:45
