Using the Baldrick's excellent guides previously posted, using DVD decrpyter and DVD2One/DVDshrink/instant Copy how do I back-up a double sided DVD to a single sided 4.7Gb? In other words how do I join the two parts into one before shrinking.
many thanks
I can't believe that I"M giving advice but it seems like everyday someone is asking the same question.
In general if you search the forum, you will find your answer. Below are links to methods that I used. I was able to make Goodfellas and Stargate into single disks.
In retrospect, how much is it worth to you to join them. Is the extra $1 and having to get up in the middle of the movie worth it?
http://ifoedit.wh.fr0zen.com/joinclip.html#joindbl
http://ifoedit.wh.fr0zen.com/createifo.html -
you're right its not worth, hence I have backed up onto two disc's.
Sorry for the obvious question, but as this site gets more popular it's harder to find the older guides.
New to double sided dvd's - Burning Hi Quality Media Files
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2012, 21:50 -
Double-Sided, Dual-Layer DVD media?
By dgpretzel in forum MediaReplies: 22Last Post: 15th Apr 2008, 16:03 -
Dual-Layer Double-Sided DVD's turnover?
By Deisel Weisel in forum DVD & Blu-ray RecordersReplies: 6Last Post: 22nd Nov 2007, 22:23 -
do they sell double sided, single layer dvd's (DVD-10 - the ones you flip)?
By cduval04 in forum Newbie / General discussionsReplies: 12Last Post: 24th Oct 2007, 11:40 -
How do I convert double sided dvd to dual layer dvd?
By acid_burn in forum DVD RippingReplies: 2Last Post: 22nd May 2007, 05:04
