    Mar 2003
    London UK
    Using the process as outlined in the excellent guides previously posted, using DVD decrpyter and DVD2One/DVDshrink/instant Copy how to I back-up a double sided DVD to a single sided 4.7Gb? In other words how do I join the two parts into one before shrinking.
    many thanks
    8) :P
  2. Member steptoe's Avatar
    By double sided, do you mean a DVD-9 or a DVD that comes on 2 disks ???
    If its a DVD-9, then use the guides
    Personally, I'd use the guide that covers the copy using :
    DVDDecryptor
    DVD2One
    Copy2DVD
    Thats all you need to copy ANY single DVD, including all menus and features, weather its a DVD-9 or a DVD-5
    If its a DVD-5, then it will be better quality than a DVD-9, as it has to squeeze what is essentially 2 DVD's onto one
    If you don't know what I'm talking about, read the guide that covers the difference between DVD-5 and DVD-9 formats. This is what I assume you mean by a double DVD
  3. I think he is talking about a double-sided DVD (Goodfellas is an example) that is acutally a "flipper." It is basically a double-sided DVD-5 (which some refer to as a DVD-10).
    You have to end up renaming the VOBs on the second side to match the naming convention of the VOBs on the first side.
    Then re-create the VOB IDs using IFOEdit. There is a guide somewhere in here, but I was unable to locate it in the 2 seconds I looked. Search the guides for DVD-10.
    Mar 2003
    London UK
    I was refering to a flipper, and the disc I'm trying to back-up is Goodfellas!
    Thanks for the advise will try.
