Sorry if this a bit of a noob question but I'm having trouble playing svcds on my dvd-rom.
The playback is jerky and the dvd drive sounds like it working overtime. I have no trouble though if I extract the mpg and play that (although obviously I would prefer to play from cd to save hd space)
Check that DMA is enabled on your DVD-ROM drive. What OS are you running? What DVD Player software are you running?
What is the source and encoding method of your media ?
DMA is enabled. I have XP and WinDVD 3.0...
Source and encoding?? ermm its Centropy releases of Identity and The Hunted if I'm allowed to say that....thanks guys... -
Source, as in "DVD", "AVI"...
Encoding method as in "What encoder?" "Which settings?" "What bit rates?" "How did you burn?" "What media used?"
To me, that sounds like a bad burn (the dvd drive sounds like it working overtime.)
Try burning at lowest speed (2-4x) and see if that helps.
/Mats
Problems playing .mkv on a LG BD550
By Pipster2797 in forum Blu-ray RippingReplies: 15Last Post: 9th Jan 2017, 06:53 -
Problems playing Hi 8 tapes with my camera
By roscoe47 in forum Newbie / General discussionsReplies: 1Last Post: 12th Jul 2011, 11:43 -
Major Video Playing Problems..
By SpazRaven in forum Newbie / General discussionsReplies: 6Last Post: 21st May 2011, 15:43 -
MPEG playing problems
By Dave Knowles in forum Software PlayingReplies: 5Last Post: 14th Oct 2007, 07:31 -
Problems with recorded TV playing
By amir77a in forum Media Center PC / MediaCentersReplies: 4Last Post: 15th Jun 2007, 07:57
