    May 2002
    Austin, TX
    I know I've seen it before, but don't remember where now...how to navigate to the checkbox that tells VS7 Not to reencode(render) compliant video files in it's authoring process.
    Can someone please tell me the steps to finding where that setting/checkbox is again, Please?
    "Signature"......
    I use a Dazzle capturing system that Only lets me capture into Mpeg. So that is all I work with. I never do any DV/AVI video.....
    Apr 2003
    Santa Cruz
    When you go to the last of the menu item “share” click on little triangle next to it and choose create disc.
    On the next screen on the bottom left click square like check mark, and then you have an option “Do not convert compliant MPEG files”
    May 2002
    Austin, TX
    OK thanks, Dasio
    Are you in Santa Cruz, California?
    I'm "land locked" now, but spent many happy days surfing Steamers Lane, Pleasure Point and "The Hook" out there in the 60's.
    Is that the Santa Crus, where you live?
    "Signature"......
