  1. Hi Everyone!
    I'm trying to backup my first Fellowship of the Ring (the Special Edition NOT the Extended Version) and for some reason, the audio is off-set by around 1-1.2 seconds. I didn't do anything different to what I do normally using DVDDecypter and DVD2One.
    The 2-channel Dolby Digital soundtrack works fine but it's the Dolby Digital 5.1 that has gone out-of-sync.
    Does anyone know how to go about re-syncing the audio? I've never done it before and I think it'd be really useful. I'd appreciate any help!
    Thanx!
    boodo
  2. Use Eazy Vcd from the tools menu if you want a simple method with no errors.
    If it's wet, drink it
    My DVD Collection
  3. hardcoreruss,
    I'm not exactly sure what you mean. Do you mean use EasyVCD or is there an option within DVDDecrypter? If there is, I can find one.
    I just want to backup of my Fellowship of the Ring on a DVD and only want to resync the audio from the VOB's I've extracted. I've tried it twice and the 2-channel Dolby worked fine in both instances. It's JUST the 5.1 mix that is off-set.
    Any ideas?
    Thanks!
    boodo
