yea another damn video clip, recently i downloaded a video clip from internet which have unknown audio format.I tried to play it with every player i known but none of them worked, morover, The video format is DVDRip.DivX.
I decided to view the information of this video well i opened it with Virtualdub and it wrote down in' Audio stream section' this:
sampling rate:48000Hz
channels:5 stero
sample precision:0-bit
compression:unknown(tag 2000)
preload skew:28000 samples
i don't understand these information well i decided to ask some experts
any help would be appreciate
AnonymousGuest
I have this very same error BUT I can play the file in WMP 9, VDub and WinDVD. I have not used GSpot yet but I'm pretty sure I don't have the codec, again, YET. I got it from the tools but I'm just asking for someone's opinion about WHY it can play in WMP but I can't encode it in TMPGEnc+.
you can't encode it in tmpgenc because it has 5 channels of audio and tmpg vcd only uses 2. you must change it to a 2 channel wav first.
yeah,to encode a file with ac3 you need to extract the wav with avi2wav then rename the extention to ac3 then convert to wav with HeadAC3he.
or just extract the wav with goldwave.
Unknown audio in AVI files
By courtneye in forum AudioReplies: 6Last Post: 29th Sep 2011, 10:24 -
Ripping CD (Enhanced Video) Unknown Format
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 30th Jan 2011, 20:20 -
Adventures in importing... unknown format in .mov wrapper
By vidhelp22 in forum Video ConversionReplies: 2Last Post: 19th Oct 2010, 23:30 -
Capturing unknown format video 8
By Bigby in forum Capturing and VCRReplies: 17Last Post: 28th Sep 2009, 09:10 -
How to Capture Video of "Unknown" Format from a DVD
By Hombre7 in forum Newbie / General discussionsReplies: 7Last Post: 11th Jan 2009, 12:14
