I use dvd2svcd to put my dvd under svcd.
I got some probleem with CCE encoder and i use TMPGEn vbr 2 pass
Is it possible to impose 60 minutes film on 1 disk as it is with cce
Tanks for support![]()
géma
TMPGenc has a "source range" feature. With that you can exactly decide how much of your film you want to encode, e.g. 60 min. in the first CD, and then the rest in the other CD. But better is to split the film into 2 parts.
Assuming you use an SVCD template and you've unlocked it, if you have the registered version of TMPGenc (I am not sure about the free one) and use the wizard, it will ask you in the end if you want to fit the size of a CD. You can choose between 74min and 80min. disk.
Then it will compute the speed automatically for you and encode.
This does not mean your film will be necessarily 74 or 80 min. , that number is just nominal speed for a music CD.
It could well be a 60 min film as you want.
TMPGenc built in calculator is somewhat conservative. If you use FITCD you'll get slightly higher speed values than TMPGenc and the disk will still be fitting. -
If you simply change the encoder to TMPGEnc in the DVD2SVCD Encoder control, the same rate control should be used so the same disc size calculations will be done. You can most definitely fit a 60 min. film on one disc using TMPGEnc.Originally Posted by gemacela
BD Rebuilder - What Size Disk Are You Making
By wulf109 in forum Blu-ray RippingReplies: 9Last Post: 15th Dec 2009, 19:52 -
Encoding AVI's by Size
By OrchestraAndChoir in forum Video ConversionReplies: 6Last Post: 15th Sep 2009, 15:40 -
Impossible to get the right file size after encoding
By cd090580 in forum Newbie / General discussionsReplies: 7Last Post: 4th Dec 2008, 11:14 -
Creating / converting DVDs with Devede: Disk usage bar underestimates size!
By nicolaidenmark in forum LinuxReplies: 4Last Post: 22nd Aug 2008, 23:09 -
Hard Disk Space When Encoding
By Em in forum Newbie / General discussionsReplies: 8Last Post: 21st May 2007, 12:35
