  1. I have been using TMPGenc and CCE to encode my analog captures for a while. Recently I bought a digital camcorder, and made my first tests of capturing video from the camcorder and converting to DVD. TMPGenc opens and encodes the digital avi file without any problem: however, when I try to encode with CCE (v. 2.5) I get a message saying that the codec is wrong or missing. What should I do to solve this?
  2. Member DJRumpy's Avatar
    Dallas, Texas
    You AVI is probably Type-1 DV. I don't remember for certain, but I think that old version of CCE requires Type-2 AVI. You need to convert it to Type-2 using one of the freeware converters in the Tools section.
    Impossible to see the future is. The Dark Side clouds everything...
  3. You were right (as usual ). I have tryed with CCE 2.66 and it worked nicely. Thanks again for your support (what would we do without you?)
  4. Member DJRumpy's Avatar
    Dallas, Texas
    Any number of people here could have answered for ya. I just have too much time on my hands, and I'm a fast typer :P
    If you don't want to go to a newer version of CCE, you can just use a converter. If you can though, stick with the newer version. The features/fixes are worth it.
