I am interest to backup to my Sony DV camcorder a few home videos that are in VHS tapes. I donīt have cables and adaptors to connect the videorecorder to the videocamera. However, I have a firewire connection between the computer and videocamera, and I have also a connection between the videorecorder and the computer through an analalog capture card. I wonder if I can use the system as it is, capturing from VHS to the computer and then recording back the files to the digital camera.
With Scenalyser, I can capture video from the camcorder and record back. However, this only works with digital avi files; if I try to open with Scenalyser an avi file from an analog capture the preview just stays black and if I try to record to the digital camera it just records a few seconds of black picture. I have already tryed converting the analog capture (avi) to a standard dvd resolution file (avi with 720x576, 48 Khz), but did not worked.
So, my question is: is there a way to convert an avi file of an analog capture to digital avi format? Hope so!
You need an DV-AVI encoder!!!
AVI stands for Audio/Video Interleaved, which means that it could be any kind of format!!! So capturing with capturecard doesn't mean that AVI file is DV-AVI. DV-camera's ONLY support DV-AVI.
You could use the Mainconcept DV-codec but the free version places a watermark in your video...
http://www.mainconcept.com/fdl.php?downloads.mainconcept.com+DVCodecDemo2.1+dvdemocodecv2.1.exe
the registered version isn't expensive though ($49,-)
'HAG -
fingernailX,
Yes, that is also an option, BUT... Microsoft DV-codec only use quality setting 75%!!! So you will lose 25% of quality...
In other words... Microsoft codec support only 4 generations of encoding, while mainconcept encoder supports more than 10!!! Thus much better quality!!!
'HAG
Read this post....
https://www.videohelp.com/forum/viewtopic.php?t=157949 -
If I recall correctly, both the Canopus DV Codec, and the Panasonic DV codec are free (find them in the TOOLS section). I don't use DV, but I'm sure someone here could tell you if their any good.
Impossible to see the future is. The Dark Side clouds everything... -
Thanks all for the suggestions. Going to chase some codecs (or to buy some cables if I fail)!
Convert VHS tapes to digital files
By Rogerwodehouse in forum MacReplies: 5Last Post: 20th Jul 2011, 15:55 -
convert mp4 Sony digital photocamera
By surfer in forum Video ConversionReplies: 2Last Post: 11th May 2011, 08:57 -
Help Converting VHS to Digital - What Format to Convert to?
By Jobbers in forum Video ConversionReplies: 8Last Post: 1st Apr 2010, 09:09 -
Best way to convert VHS to digital while preserving quality?
By Jabroni4872 in forum Video ConversionReplies: 2Last Post: 8th Oct 2008, 01:59 -
Convert my digital photos to a DVD
By hufri01 in forum Authoring (DVD)Replies: 5Last Post: 7th Mar 2008, 06:16
