I've previously bought two batches of 50 (each) Accu DVD-Rs from mertline.com (http://www.meritline.com/ac47dvsilbla1.html). I've been extermly happy with these. They've played without problem in my Toshiba SD2800 settop player. I recently ran out and wanted to reorder but found out that merline is out. So I went to ebay and bought 50 "Accu" DVD-Rs from there. This batch is terrible. I get a lot of blockness when I try to play them in my settop DVD player. Also, my Sony DRU-500a can't even read the discs back after burning them! What's up with that!? So I thought I'd check them out with ADVDInfo. I get the following when I try to read the, "0E - Pre-Recoreded Information Lead-In" information:
"Aspi Command Returned; Sense Key 05h; ASC 24h; ASCQ 00h".
Here's what I got for the 1st batch of 50 (from meritline.com):
00 6A 00 00 01 40 C1 FD 9E D8 50 00 02 87 0D 13 .J...@....P.....
88 99 80 00 03 4C 65 61 64 20 44 00 04 61 74 61 .....LEAD D..ATA
20 20 20 00 05 00 00 00 00 00 01 00 00 00 00 00 .............
Here's what I got for the 2nd batch of 50 (from meritline.com):
00 6A 00 00 01 40 C1 FD 9E D8 50 00 02 89 0E 13 .J...@....P.....
87 88 80 00 03 53 4F 4E 59 00 00 00 04 00 00 00 .....SONY.......
00 00 00 00 05 88 80 00 00 00 01 00 00 00 00 00 ................
What in the heck are the discs I got off of ebay? Lesson learned (for me anyway) is don't buy unbranded bulk DVDs from ebay. I'll stick with meritline.com in the future for Accu DVD-Rs. Also, can anyone recommend any reasonably priced alternative to Accu DVD-Rs that work well with the Sony DRU-500a?
Most of my Leaddata discs turned out terrible. Horrible media. The "Sony" discs you have are probably a fake code on some crappy media. I forget which one. It's been posted before.
I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored. -
Originally Posted by txpharoah
I just flashed my DRU-500a firmware to 2.0f (from 1.0f). This made all the difference with these discs. These discs are now readable in my DRU-500a drive and seem to play well in my Toshiba SD2800 (I've only tested one disc though after flashing). Also, this flash seems to correct a "cyclic redundancy error" (read error) I got about 60% to 70% of the time with these discs (and the ACCUs discs) when I tried to read them in my NEC DV-5700A DVD-ROM drive (see https://www.videohelp.com/forum/viewtopic.php?t=159694&highlight= ).
The only downside is that these discs now burn at 1x instead of 2x.
which 'create DVD from MP4" app for Mac that takes any kind of MP4?
By callagga in forum Authoring (DVD)Replies: 1Last Post: 25th Jan 2012, 19:46 -
Lightscribe: what kind of DVD
By themaster1 in forum ComputerReplies: 8Last Post: 30th Jan 2010, 16:16 -
Is this a VH glitch of some kind ?
By Seeker47 in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2009, 13:09 -
what is this for kind of codec.
By Cazz in forum Newbie / General discussionsReplies: 1Last Post: 12th May 2009, 15:18
